Kupe's Zodiac 650B
Date: 2-6-2013
Number of Hours: 2.00
Manual Reference: 6-T-2A & B, 6-T-3A
Brief Description: Final Prep, Elevator Start
Did the final prep for the stabilizor which involved a little disassembly, deburing, and anti-corrosion painting of the tip ribs and hinge areas.
While I was waiting for the Cortec to dry on the stab parts, I started on the elevator by prepping the 2 middle elevator ribs to hold the elevator center channel. This was accomplished by cutting, filing, drilling, then cleco-fastening a custom fit "L" bracket to one side of each of the two ribs. The "L" brackets came from what was once the 4 foot-long piece of "L" bracket that was also used to attach the tip ribs to the stab spars. After adding these to brackets to the elevator ribs, I still have over 2.5 feet of "L" bracket remaining. Hopefully that's enough for whatever future use I'll have for it.
I then clamped, drilled, and cleco fastened the elevator center channel to the ribs via those custom "L" brackets and set it aside...
...because the Cortec had dried, so I reassembled the stab to be all ready for riveting tomorrow.
Horizontal stabilizer, all reassembled and ready for riveting.
The first couple of rivets were pulled by the Builder in Training.
First task for the elevator - mounting the center channel onto the center ribs.
