Kupe's Zodiac 650B
Date: 1-26-2013
Number of Hours: 2.00
Manual Reference: 6-T-1A, B, & C
Brief Description: Spars and Ribs Pre-Assembly
Went to my first Experimental Aircraft Association (EAA) local chapter meeting today. It's Chapter 186 at Manassas Airport (KHEF) and this year is their 50th year in existence. Looks like I got in with a great group of folks. They have regular monthly meetings, several events per year, and a membership of over 250 people. They have cheaply rentable hangar space for final assembly before the airworthiness inspection and a ton of "too-expensive-to-own-privately" items like a weight-and-balance scale set and a trailer big enought to haul most airplane bodies. Several of them have built or purchased Zenith Zodiacs - I definitely want to meet them.
After the meeting I was motivated to do some work, so I continued on the horizontal stabilizer. As I started reading through the Photo Assembly Guide to get my bearings, I noticed a significant difference between my guide instructions and the pieces delivered to me from Zenith - and it was a GOOD difference. It seems that every piece in the stabilizer skeleton (spars, ribs, doublers, spar attachments) were all pre-drilled. And not only were they pre-drilled, they were already drilled to the final size (i.e. beyond pilot hole, #40 drill bit size)! That saved me a couple of hours of lining up, clamping, and drilling.
All those pre-drilled holes didn't help me in figuring out front/back/top/bottom on the spars and even with the holes, it's not an idiot-proof assembly section. But eventually I got it sorted out by re-re-reading the plans and Assembly Guide, went back and removed all my incorrect and crossed-out sharpie annotations (furtively rubbing them off with paint thinner and a rag!) and pre-assembled 80% of the stabilizer skeleton. All that's left are 4 x 75mm "L" brackets I actually get to "fabricate" from a 4 foot-long piece of "L" bracket to attach the 2 tip ribs to the skeleton. Maybe tomorrow after flying.
Front spar attachments cleco-fastened in place.
Rear spar attachment, the one I spent a couple hours on two days ago, cleco-fastened in place.
The core of the horizontal stabilizer skeleton minus two tip ribs.
