Kupe's Zodiac 650B
Date:  12-19-2013
Manual Reference:  6-W-8
Brief Description:  Right Wing Final Debur and Paint
Finished off the right wing final prep by deburring, sanding and painting all the upper wing skeleton parts in anticipation of final riveting in a few days. Just a few more tasks until completion.
I also performed one of those tasks this morning by installing the aileron bellcrank channel spanwise supports to the aileron bellcrank channel. These supports add additional reinforcement to the 7th rear rib where the bellcrank is attached by attaching to the 6th rear rib and the top & bottom skin between the two ribs. Image #3 below shows the two top supports as well as the two bottom supports which were installed with the bottom skin last month.
Front half of the skeleton deburred, sanded and painted.
Rear half of the skeleton deburred, sanded, and painted.
Aileron bellcrank channel supports installed.
