Brief Description: Wing Locker Back Wall, Dzus Strips
Added rivet lines to the left & right edges and the bottom flange of the wing locker rear wall and drilled them out. Then I secured the rear wall to the #4 and #5 rear rib L-angles, drilled than out and clecoed them in place.
I also drilled out the outboard and rear dzus strips.
Wing locker real wall and dzus strips all drilled out to pilot hole size.
