Brief Description: Right Wing Bottom Skin Debur, Sand, and Paint
Finished deburring the bottom skin (rivet holes and edges) and the lower flanges of the ribs, main spar and rear channel. sanded all the edges and those surfaces receiving paint. Masked off the rivet holes on the top side of the bottom skin to prevent corrosion control paint from seeping through. Painted all the planned mating surfaces with cortec. It dries celar. No really, you can't see it!
Top side of the bottom skin with rivet holes masked off.
Under side of bottom skin and skeleton after painting (yep, it dries clear!).
