Kupe's Zodiac 650B
Date:  7-10-2013
Manual Reference:  6-W-8
Brief Description:  Left Leading Edge Skin Final Prep
Deburred, cleaned, sanded, masked and painted the left wing leading edge skin. I also took the opportunity to clean off the layers of finger smudges all over both sides of the skin. I didn't have much luck using denatured alcohol, so I grabbed a bottle of ArmorAll Wheel cleaner and that really got things cleaned up in a hurry. However, when I went to apply masking tape to the skin to protect the rivet holes from anti-corrosion paint bleed-through, I found the tape slid off the metal like I was trying to tape teflon. I guess ArmorAll's protectorant is in all their products. Next I used some Windex on the leading edge skin to remove the ArmorAll. After that, everything was fine.
Outside of the leading edge skin with masking tape over the rivet holes.
Inside of the leading edge skin while the paint is drying.
