Brief Description: Wingtip and Landing Light start
Drilled out the bottom and aft portion of the fiberglass wingtip and measured for the installation of the left nav/strobe light.
Put together the optional landing light assembly in preparation for installation. Cut out the hole in the outboard leading edge of the left wing and tested the landing light plastic cover for fit.
Bottom and aft of the wing tip drilled out and clecoed, Set the drill marks for the nav/strobe lights
Landing light assembly and the leading edge where it will eventually reside.
