Brief Description: Left Wing Rear Channel - Complete
Finished off the left wing rear channel this morning. Reassembled the channel and riveted with A5 rivets. Took it back upstairs from the basement to the garage (yes, it fit ... barely) and re-clecoed it to the aft ends of the rear ribs. Next will be the rest of the skeleton after I figure out where to put the skins while I work on the skeleton (Hint: this will probably involve a temporary encroachment into the not-my-side-of- the-garage spaces).
I also cut out the aileron balance bar hole near the outboard end of the rear channel. It still requires a little filing and sanding.
Rear channel all riveted up on the basement workbench.
Newly riveted rear channel back in the garage clecoed to the rest of the wing.
