Prepped Nose Ribs #1 - #3 (NR#1-NR#3) by cutting out an 8mm x 40mm notch on the rear web and flange on the top and bottom. The reason for the notch is so the web will fit between the upper and lower spar doubler (bracing) on the top and bottom of the wing spar in the first three NR positions (see image 2).
Additionally, I drilled out the fuel line holes in NR#1 and NR#2 and inserted rubber grommets into them then added the fuel line access hole to NR#3. All six inboard nose ribs are ready for assembly with their respective wing spars.
Left side NR#1-NR#3 with rear web notches and fuel line holes drilled out.
Left wing spar showing the upper and lower spar doubler the notches will accommodate.
