Kupe's Zodiac 650B
Date: 5-2-2013
Number of Hours: 2.00
Manual Reference: 6-W-6
Brief Description: Aileron Bellcrank Support
Today I went into fabrication mode. Using only a few handtools, I created 4 bellcrank supports out of 4 chunks of 1/8" thick extruded L angles (two of them shown in Image 1). A top-of-the-line vertical bandsaw would've been nice to have, but in reality I'd rather have better avionics or a bigger engine and forego the uber tool.
So, beginning with my first extrusion, I measured out the center point for the bolt hole and drilled a pilot hole into it. Then I took a 20mm diameter Dremel sanding disk and clecoed it to the extrusion. This gave me the required 10mm radius from the center of the bolt hole. I then drew 2 straight lines from the lower corners of the extrusion to a tangent on the 10mm radius arc. I had my shape drawn out.
Next, I clamped the annotated extrusion into a table clamp, got out the 32 teeth-per-inch hacksaw, sprayed a little WD 40 onto the metal, and began sawing. I was careful to stay off the lines I'd drawn so I wouldn't have to start over with new materials. The results were a rough, but workable bellcrank support as shown in Image 2.
Then I brought out my trusty files and began chewing away at the excess, filing ever more closely to the lines on the extrusion. Starting with a rough cut file, I made short work of the excess material and rounded off the corners from my hacksawing. I followed up with a fine cut file which brought the edges right down to the lines and gave them a polished look. Finally, I finished it off with a 3M 400 gril sanding block and updrilled the pilot hole to 3/16".
After finishing the 1st support, I used it to trace out the remaining 3. The subsequent bellcrank support fabrication went pretty fast after working my way through the first one (see Image 3).
Two of the 1" x 1 1/2" x 1/8" extrusions out of the crate.
The first extrusion after the hacksaw cutting.
All 4 bellcrank supports ready for rear ribs #7L and #7R.
