Kupe's Zodiac 650B
Date: 4-16-2013
Number of Hours: 2.50
Manual Reference: 6-W-2
Brief Description: Left Aileron Debur, Cleanup, Corrosion Control
Performed final cleanup on the left aileron to get it ready for riveting including:
- Deburring ribs, skins, and various hardware parts (balance bar, trim tab horn, aileron horn, L angles, etc). - Rounding out of inside corners (balance bar opening, trim servo arm opening, trim tab cut out, etc). - Removal of all parts labels using paint thinner. - Removal of all external markings with denatured alcohol (annotations, line markings, factory stamps on the skin). - Trimming of hinge pins for aileron and trim tab. - Drilling safety wire holes for aileron and trim tab hinges. - Sanding all surfaces receiving corrosion control with a 3M scouring pad. - Sanding all rib and skin edges smooth using 3M scouring pad. - Painting all to-be-riveted surfaces with Cortec VpCI 373.
Tomorrow is riveting day.
Everything deburred sanded, rounded, smoothed, cleaned, and painted w/corrosion control.
