Kupe's Zodiac 650B
Date: 5-24-2013
Number of Hours: 1.50
Brief Description: The Big Flip
I finally got to the point where I needed to flip the wing back over right-side-up so I could finish drilling out the nose skin. If you recall, I manually flipped the wing upside-down in the first place by first stabilizing the wing in a vertical position with the main spar face down on the work table. With the nose ribs in place this would not be possible, so I had to try something else.
That something else came in the form of a long piece of PVC pipe and a pulley system attached to the ceiling of my garage. The The pulley system is a product called the Racor Ladder Lift (http://www.racorstoragesolutions.com/p/detail/ldl-1b) which is designed to store a ladder out of the way on your garage ceiling. The Racor kit only comes with one pulley set since the ladder initially rests in a stationary hook attached up on the ceiling and the pulley is only used to raise the other end. I purchased two of them so that both ends could be raised independently. Also, the pulley system has a built-in locking mechanism, much like a venetian blind, which allows to to raise/lower in small increments and then move to the other end and do it again.
So this morning I installed the 2 pulley systems (~45 minutes) and flipped the wing back right-side-up (~45 more minutes). The job was a bit nerve-wracking until I knew I could trust the pulleys to carry the weight, trust the locking mechanisms to hold securely, and trust the PVC pipe to maintain its rigidity throughout the process. Once I got past all that, the job went pretty smoothly. Next time, I'm going to enlist a second person to help with the fine horizontal positionin required to land back onto the supports - should be an easy job for anyone to do.
Pulleys installed, PVC in place, and the wing being lifted the first few inches. Holding my breath...
Wing pulled higher and half-way rotated to right-side-up. Looks like this might work!
Just before final touchdown. A lot of small horizontal nudging here to land on the right spot.
