Kupe's Zodiac 650B
Date:  4-8-2014
Number of Hours:  1.50
Manual Reference:  6-B-9 & 19
Brief Description:  Brakes Install and Flap Actuator Start
Installed the brake cylinders and rudders. Had to make some adjustments to the toe pedals so will rivet those later after I touch up the paint which was dinged during the fitting/readjusting.
Also began installing the flap actuator. Step one is to fabricate two flap torque tube bearing supports.
Riveted cabin floor, right side up, with rudders and brakes going in.
Flap torque tube bearing supports - before and after fabrication.
