- Determining the proper position of the door with regard to the dip stick/filler port. -- including the proper angle for removing the dipstick. - Marking the door outline on the upper cowl by tracing the door panel with a sharpie. - Cutting out the door opening with a Dremel cutting blade then filing and sanding it smooth. - Attaching the Dzus spring to the door frame to suport the locking latch. - Drilling out the hinge to the door. - Assembling the door with the door locked with the Dzus fastener and the hinge taped to the frame. - Centering the assembled door over the hole already cut into the upper cowl. - Drilling out the hinge and door frame into the upper cowl.
Next, I'll updrill everything and attached it permanently with rivets.
Oil access door cut out, filed, sanded, and drilled out for the hinge and frame.
