Kupe's Zodiac 650B
Date:  6-30-2015
Number of Hours:  1.00
Brief Description:  Baffles FItting 3
Finished up the baffles fitting by cutting out the left baffle using the same technique I developed yesterday: cut off the large, excess pieces using the nibblers and perform the final cuts using tin snips. Once all the cutting was complete, all the edges were filed, corners were rounded off, and the new cut and filed areas were all sanded smooth.
Both baffles have completed their initial fitting. The next work with them will be to attach baffle seal (wide rubber strips) to the top edges of the baffles when I work on fitting the top cowl.
Both baffles, after cutting, temporarily attached in place.
A slightly angled view to see the differences between the left and right baffles.
Both baffles from behind.
