Assembled three 9-pin D-Sub connectors that will be used to connect the wiring in the wings to the wiring already running through the fuselage (see picture 3 below). Nothing super fancy. The right wing DSub was a simple 3 wire connection for the nav lights, strobe lights and strobe synchronizer wire (the AeroLED installation calls for the ground to be attached to the aircraft structure near the light for RFI reduction). The left wing has 2 D-Sub connectors. The first includes the 3 Nav/Strobe wire connections, plus it has the four wires connected to the landing/taxi lights (1 each power and ground). The second left-side D-Sub is for the 5 wires connected to the Ray Allen aileron trim motor (power, ground, up, down, and indicator).
9-pin D-Sub connector wiring diagrams.
View of the three completed connectors and their associated wing.
Left side of fuselage where 2 of the DSubs exit into the wing.
