Brief Description: Wiring Through the Cockpit Complete
After a week nursing one heck-of-a bad cold, I finished the wiring through the cockpit task by adding the final nut plate to the forward wiring bracket and test fitting the interior side panel. I also routed the ADS-B antenna cable down along the middle spar upright and secured it in place with a zip-tie mount to where it runs under the passenger seat.
All 4 wiring brackets complete. ADS-B antenna cable also secured.
