Kupe's Zodiac 650B
Date:  8-24-2016
Number of Hours:  1.00
Brief Description:  Avionics Bay Wiring Cleanup 3
Continued working on the avionics bay wiring - instilling order into the rat's nest. Today I continued pulling things apart which I will continue to do until it's clear they can go back together neatly. Yesterday I had removed all the ground wires from the grounding block. Today I began taking the wires off the power panel (yep, the same one I wired them to two days ago!) to look for better paths and order in the wire approaches.
One area I improved was along the left (pilot) side where I combined the aileron and elevator trim cables, the flap motor wires, the ADAHRS cable, the landing/taxi light wires, and the left and right nav/strobe light cables into a single bundle to bring them into the avionics bay as a single group. That helped a bit for sure.
From the pilot side, all of the Dynon cables & ground wires unplugged - next, the power panel wires.
The left side wires along the pilot side (flaps, trim, ADAHRS, nav/strobe, landing taxi).
