Began fabricating the wiring for the fuel pumps today. With only a short amount of time to work on it, I started measuring the wires for both pumps and began adding terminals to their ends. I was able to thread the wire providing the main pump with 12+ volt power before knocking off for the day.
Fuel pump relay with the 12+ volt line attached.
The 12+ volt line running from the relay to the "main" fuel pump.
