Installed the elevator and aileron trim indicators into the center console. Nothing fancy here, just an installation and a little bit of wire organization. The real challenge will come when I connect the indicators to the 5-wire cables from each trim motor. Cables that will also pass through the control stick, trim motor relay deck, and power/ground. That's a project for a future date.
Back of console: Trim indicators in the right foreground.
Trim indicators installed with a quick power check.
