Finished fabricating the master switch to solenoid wire, connected it to the master solenoid, and routed it back through the firewall into the cockpit. Also finished off the starter switch wire by crimping on a ring terminal, attaching it to the starter, and routing the wire along the enginge ground wire and then up through the firewall into the cockpit.
Master switch wire connected to master solenoid and routed through firewall into cockpit.
Starter switch wire connected to starter.
Starter switch wire routed along engine ground then back through firewall to cockpit.
