Kupe's Zodiac 650B
Date:  9-10-2020
Number of Hours:  4.00
Brief Description:  Oil Line Tighten / ADAHRS Secure
Three upgripes from the first flight dealt with today:
- Exhaust pipe opening was too small leading to scorching of the lower cowl during flight. Opening was ground out to a larger size.
- 3 oils drops on inside of lower cowl. Retightened all connections in the oil system.
- ACTV ADAHRS VIBRATION caution light on Skyview system screen twice during flight. Riveted in 2 L-angles to stiffen the floor around the ADAHRS mount behind the cockpit area.
Ehaust pipe opening too small - caused some burning.
3 drops of oil on lower cowl required retightening of oil lines.
ADAHRS vibration caution led to floor stiffeners around ADAHRS.
