Installed a prop for the left wing locker door so that it remains open unattended and doesn't become over-extended if it gets caught in the wind. The installation was simple. I purchased a standard gate hook lock and moved it along one of the L-angle braces on the locker door until the hook end aligned with the forward-inboard zeus fastener hole. After match-drilling a couple of rivet holes with the hook attach bracket, I riveted the hook bracket to the L-angle brace.
When not in use, I fashioned a cradel for the hook from a nylon adel clamp so that when the door is closed, the hook is held securely in place by the clamp.
Standard steel gate hook sitting on the wing for this picture of it.
Gate hook riveted to door and secured to zeus fastener hole. Nylon adel clamp is on door.
