Kupe's Zodiac 650B
Date:  1-15-2019
Number of Hours:  3.00
Brief Description:  Fuel Flow Test: Nose High
Before beginning the nose high tests, I tarted out this session by running the nose level fuel flow test on the right side. I had previously run this test on the left side while I was emptying the left tank to calibrate the right fuel level. For this test, I just used the pitch indicator on the Dynon Skyview to assure level flight and recorded the time it took to fill a 1 gallon gas can. I performed this using the primary fuel pump, the secondary fuel pump, and both pumps together. Final average fuel flow right tank, level attitude: 53.7 gph with variation under 1 gph.
Next, using a modified auto ramp, I rolled the nosewheel up onto the ramp resulting in just under a 12 degree nose high attitude. By adding a nearly full jerry can to the top of the horizontal stabilizer, the nosegear extended to raise the pitch to just under 15 degrees nose high. From there I ran tests for the left and right tanks. Average readings per side were:
Left side, nose high: 61.3 gph
Right side, nose high: 51.4 gph
I also ran both tanks down until the pumps started cavitating. Fuel remaining in each tank from the nose high test was under one pint (using the fuel drain).
Aircraft in position for nose high fuel flow tests.
