Brief Description: Cabin Heat 4: Control Cable/Skeet Hose Install
Measured, cut, installed, and secured passenger side cabin heat control cable. Measured, cut, installed and secured the Skeet hose leading from the heater muff to the passenger side cabin heat pass through.
Passenger cabin heat control cable running down firewall to control valve/pass-thru.
Passenger side skeet hose after completing installation.
