Began work connecting the pitot/static hoses from where they enter the fuselage from the left wing to the Dynon Air Data, Attitude and Heading Reference Systems (ADAHRS) - the brain that sends all my aircraft performance information to the screen in the cockpit. The ADAHRS is already installed, so all that is required is the connection of the hoses.
After an initial fitting, I realized I would need additional support for the hoses between where they pass through the rear frame channel (aft wing spar where it passes through the cockpit). So today was spent measuring and fabricating a brace that will attach to a Z-angle brace half way between the ADAHRS and the aft spar.
Fabricated brace to support pitot/static lines between the rear wing spar and the Dynon ADAHRS.
