Kupe's Zodiac 650B
Date:  7-25-2018
Number of Hours:  3.00
Brief Description:  AileronBellcranks Completion Final
Assembled the aileron connections (finally) with the appropriate bolts, washers, and fender washers. Initially, I put one of the two required washers in the wrong place causing a definite binding in the aileron movement. A quick trip online showed me the proper order and after torqing everything in place, the ailerons now deflect smoothly and in the proper amount both up and down.
Left aileron access panel on underside of wing.
Left aileron bellcrank with pivot bolt and rod end bolt with fender washer.
From access panel to aileron horn with it's miniature fender washer in place.
