Brief Description: Aileron Bellcranks Completion Part 1
No Pictures.
Set out today to finalize the aileron connections by adding the fender washers and torquing the bolts at either end of the aileron pushrod in preparation for rigging the aileron control cables. Ran into a few problems that require further examination before completing to include:
- The ground down fender washers for the aileron end of the pushrod still cause interference and require further grinding.
- The left aileron deflection is off. Should be 11.5 degrees +/- 1 degree both directions. Mine is +16 and -7.
- The right aileron hits the aileron stop at 8 degrees down aileron.
Tasks for the next time - Second (left) eye cataract surgery tomorrow.
