Brief Description: Left Forward Interior Panel Install
Finished up installing the left forward interior panel. After considerable trimming and adjusting I was finally able to get this piece to:
- Fit around the fuel hoses entering from the wing - Fit under the instrument panel gusset - Slip behing the floor panel gusset - Edge under the fresh air Sceet hose - Slide into the bracket I fabricated for it.
All that's left to do is to rivet the bracket to the verticle rib and clean up the uphostery on the back side of the panel in the areas I trimmed off the backing.
Fabricated a mounting bracket to attach the side panel to a verticle rib.
Not bracket on the right (forward) side of the side panel.
