Spent the day re-routing wire bundles and pitot/static hoses in the wing root of the left wing. It turns out the exit point I chose 4 years ago for the wires and hoses was in an area with minimal space available for bend radii. To fix the problem, I rerouted the hoses outboard of the inboard rib to the rear end of the wing root where there is more space for adjusting. I also snugged the wire bundles down more securely to keep them inside the narrow space between the wing inboard rib and fusealge side. A preliminary test fit indicates this will work well.
Re-routed pitot/static hoses and more closely secured wiring.
