Began the process of fitting the rudder to the fuselage. This involves attaching the lower and upper hinge brackets to the rudder. The lower hinge bracket is easy, but the upper bracket needs to be fit to the hinge point already installed on the fuselage. The placement of the upper hinge on the rudder required some trimming of the aluminum skin that wraps around the front of the rudder which is a part of the plan. After trimming the skin, I put the rudder aside for the time being.
