Kupe's Zodiac 650B
Date:  2-8-2017
Number of Hours:  1.00
Brief Description:  ADAHRS Leveling Shims
Removed the ADAHRS from the belly and fashioned a couple of shims from 0.032" aluminum to raise up the left side of the mounting bracket to zero-out the 0.5 degree left tilt. I also drilled a pilot hole in the side of the upper part of the bracket. Once the assembled bracket is leveled fore-aft and the hinge bolts are set, I'll finish drilling the pilot hole through the the lower bracket hinge, and rivet the two together so that the ADAHRS doesn't creep in pitch over time. Shout out to my TA Rob Brooks (also with a build log on this site) for this tip.
ADAHRS mounting bracket with 2 shims ready (in case 1 isn't enough).
Right side of ADAHRS mount. Note the small pilot hole for a rivet to lock the fore-aft in place.
