Kupe's Zodiac 650B
Date:  10-17-2016
Number of Hours:  1.00
Brief Description:  Fuel Plumbing Through the Cabin 8
This morning's task was to begin securing the fuel hoses, running forward of each seat, to the cabin floor. To do this, I installed 2 cable tie mounts on each side then secured the two hoses to each other (return line above feed line) and the cable tie mount using a zip tie with a spacer between the two hoses. This will hold the hoses securely to the floor and back underneath the forward-slanted center wing spar.
Left side hoses secured to the floor with cable tie mounts and zip ties w/spacers.
