Brief Description: Fuel Plumbing Through the Cabin 3
Continued work on fuel lines by attaching fuel hose platform to the cabin floor and cutting out a fuel hose pass-through on the left center console side panel.
Attaching the fuel hose platform to the cabin floor was straightforward. I decided to use 4 existing rivets to keep everything neat and efficient. So I rolled under the belly on my trusty garage creeper to drill out the 4 rivets I would be using for the attachment. When I hopped back up to clamp the fuel hose platform in place for drilling through the holes where the rivets had just been removed, I discovered I'd drilled out four rivets in front of the ones I wanted! So back under I went to re-rivet those 4 holes and drill out the correct 4 rivets. After that, securing the fuel hose platform was simple even if it did require a bunch of up-and-down between the belly and the cabin.
I then cut a notch out of the center console side panel (left) to allow the left side hoses to pass through to the selector. The hole turned out to be a little too tight so I will be filing that to a slightly larger size.
Last, I clamped the 8 hose sections to the 4 right-angle fittings using oetiker clamps and set up a test fit for the left side hoses.
Fuel hose platform riveted to the cabin floor below the brake lines.
Left fuel lines resting on fuel platform with fuel selector temporarily in place.
Left fuel hoses routed along center spar base through center console side panel.
