I continued running the wiring down the right side of the cockpit today by finishing the last two wiring brackets and drilling them into position. I then began removing them one-at-a-time to add nut plates for attaching the interior sidewall. I finished off two of them before knocking off for the day.
All 4 wiring brackets match drilled in place. 2 of them have sidewall mounting nut plates.
Test fit of interior sidewall on the first 2 of 3 wiring brackets.
