Finished off the transponder antenna installation this morning by:
- Drilling a 1/2" hole through the floor of the cabin in the vicinity of the previously mentioned "X". - Cleaning up the hole by deburring and sanding it. - Installing the antenna through the hole and tightening it in place. - Attaching the previously fabricated antenna cable to the antenna. - Installing 2 zip tie mounts to one of the diagonal firewall stiffeners to secure the cable between the antenna and the transponder - Installing a "spacer" zip tie to safely pass the antenna cable across the top horizontal firewall stiffener on its way to the transponder.
It's fully installed and apparently works as I got a "Reply" indication (yellow circle with "R" in image 3) on the Dynon Skyview display indicating the transponder was responding to an interrogation! Hopefully no one noticed since the aircraft registration number I have programmed into the transponder is for a (so far) unregistered number (but it is reserved)!
Antenna near rudder pedal with cable running up the diagonal and past the horizontal flanges.
Transponder controls on the Skyview
Transponder status line with "Reply" indicator illuminated. Radio (top right) tuned to nearest airport
