Brief Description: Right Nav/Strobe Wiring and Fire Extinguisher
Assembled a 9-pin D-sub for the right Nav/Strobe lights and ran the wire down the left side, then behind the seats to cross over to the right side. This will avoid running the strobe wiring along the right side where I plan to run the VHF comm antenna cable. Looks like the bulk of my noisy wiring (2 x trim motors, 2 x nav/strobe, flap motor) will all run aft along the left side away from the comm antenna cable.
I also received the fire extinguisher in the mail so I installed it on the luggage deck behind the passenger seat where it is readily accessible from the pilot's seat.
Completed right nav/strobe D-sub connector resting above where it will penetrate the fuselage side.
Fire extinguisher bracket mounted behind passenger seat.
