Kupe's Zodiac 650B
Date: 7-16-2016
Number of Hours: 1.50
Brief Description: Elevator Trim Wiring Connections
Began the process of completing the elevator trim wiring by assembling a 9-pin D-sub connector to the end of the cable. Since the aircraft will be moved to a hangar for final assembly (wings and tail section) I'm going with a "quick connect" method for the wiring with functionally organized D-sub connectors to simplify the final assembly somewhat. Today was my first - for the elevator trim servo wiring cable. If anyone cares, I chose D-subs over other methods (Molex, Weatherpack, MIL-spec, et al) because I find them generally easy to work with, well-reinforced, and relatively inexpensive.
So my first of many connections began today with the elevator trim servo cable, which is a standard 5-wire cable commonly used with the Ray Allen servo series. It's a straightforward job to:
- Peel open the cable covering and trim it back - Strip the ends of the individual wires - Crimp a pin (of the appropriate gender) onto the end of each wire - Insert the pins into the housing, feeling/listening for a click as it seats - Enclose the wires in heat shrink - Assemble the cover around the housing
First one finished, about 9 more to go.
Strip each of the 5 wires and attach pins to each one via crimp.
Insert pins into plug housing, heat shrink, and begin plug cover assembly.
Finished plug - mail end.
