Just a brief stint in the garage today to install the fresh air vent hoses between the NACA port on each side of the fuselage to the eyeball vents on the instrument panel. This involved measuring and cutting sections of hose, fitting them in place, then attaching them with hose clamps on each end,
Pilot side fresh air vent hose from eyeball vent to the NACA port.
Both hoses installed. Note the hole in the lower left for the passenger side throttle cable.
