Kupe's Zodiac 650B
Date:  4-5-2016
Number of Hours:  1.50
Brief Description:  Center Console Switches, Displays, Controls, Plugs
Began work on installing various switches, plugs, and displays in the center console. Today I determined what items I could fit onto the console then began experimenting with various arrangements. Once satisfied with where everything would fit, I measured out the precise positions to begin drilling and cutting. The following will be installed into the center console:
- Ignition (key) switch
- Fuel selector switch (electric fuel tank selector)
- Current fuel tank indicator LED light (L and R)
- Elevator trim position LED
- Aileron trim position LED
- USB charging port (2)
- Cabin heat control knobs (L and R)
- Headset jacks, headphones and mics, 2 each
It's going to be a fairly busy part of the instrument panel!
Center console with various switches, displays, controls, and plugs marked out.
Center console items to be installed.
