After a lot of moving, shifting, turning, repositioning, and nudging, I have the avionics positioned onto the avionics shelf. The most challenging considerations were 1. leaving ample space for the various wire harness plugs and antenna jacks to stick out from the avionics without interference; 2. positioning the avionics close to where they need to be placed for wiring considerations; and 3. spacing the avionics for cooling purposes. Although I had originally wanted to include my network hub on the avionics shelf, I could not find a configuration that accomplished the preceding 3 considerations along with the hub, so I am going to mount the hub above the shelf on the firewall.
Final positions determined with pilot holes drilled as viewed from instrument panel end.
Pilot holes drilled, avionics mounted from pilot side.
