Kupe's Zodiac 650B
Date:  2-14-2016
Number of Hours:  1.00
Brief Description:  Avionics Install 1
Started determining the placement, installation and wiring of the avionics today. It's sort of like a big puzzle to be solved. The challenge is to arrange (and eventually secure) 4 avionics black boxes (transponder, ADS-B, Comm Radio, Engine Management System), a network hub, and a backup battery onto the avionics shelf I previously fabricated. The puzzle is arranging all of the pieces in such a way that the pre-made wire harnesses can reach all of their assigned attachment points and that additional wires/cables (like attenna cables, ELT connection, aileron/elevator trim, landing/taxi lights, nav/strobe lights) can still be connected to the back of the power panel.
As you can see by the rats nest in the attached images, I still have some thinking to do.
Avionics clecoed in place. Wires sticking up above the instrument panel will need to be secured lower.
From above: A glimpse of the black boxes and associated wires.
From behind the panel: Still a lot of thinking to do.
