Today's task continues with the glovebox by first match-drilling the glovebox mounting holes through the instrument panel template through the instrument panel. Then, after reassembling the glovebox to the instrument panel (and template), I updrilled the mounting holes to their final, A4 rivet size.
With the glovebox secured to the instrument panel, I reattached the door and filed the edges of the opening to loosen up some particularly snug areas of fit. Once the door was able to close and open smoothly, I temporarily installed the door latch to the door and adjusted it until it fit correctly into the locking notch in the glovebox.
Glove box updrilled to final rivet size where it attached to instrument panel.
Glovebox door latch installed, adjjusted and tested.
