Began work on the instrument panel. As part of my purchase of a Dynon Skyview suite from Zenith, they provided me a pre-cut instrument panel that will slip behind the original (blank) kit instrument panel. This provides me a template to trace onto the original panel and strenghthens the overall instrument panel installation. Since receiving the pre-cut panel, I've decided to add two x 2-inch air vents to it for individual cooling, so today I cut out the two x 2-inch holes in the pre-cut panel using an adjustable circle cutter. The holes turned out great.
I also painted the GPS mount white, like everything else in the engine bay, and reinstalled it back onto the firewall top stiffener after it dried.
Using an adjutable circle cutter, I cut out 2" holes for air vents.
