Kupe's Zodiac 650B
Date:  12-13-2015
Number of Hours:  1.50
Brief Description:  Parking Brake Final Installation
Updrilled the rivet mounting holes in the parking brake bracket from pilot hole-sized to final A4 rivet size. I then cleaned up, sanded, and painted the parking brake bracket and cabin heel support for the final installation of the bracket. Next, I riveted the bracket into place with 8 rivets. It's permanent now, although the parking brake valve can still be removed from the bracket for maintenance or replacement as required.
Next I started measuring for the firewall penetration I'll need for the wire bundle leading from the engine to the Engine Control Unit (ECU). I also ordered some ECU mounting bolts, and the aluminum tubes to secure the brake lines to the aft edge of the landing gear struts.
Parking Brake in the
Parking Brake in the "Open" position.
Parking brake in the
Parking brake in the "Closed" position.
