Brief Description: Forward Fuel Hose Routing - Begin
Started working on routing the fuel hoses from the firewall to the fuel selector valve. Luckily, there are three convenient bolts securing the two halves of the rudder pedal center bearing to the floor. By removing the bolts and adding an adel clamp to the bolt, I am able to route the fuel houses and the brake lines down the middle without coming into contact with the rudder pedal assembly or rudder cables.
The feed line (blue) was easy and was attached to the forward bolt. The brake lines were also easily clamped using the center bolt. However, the return line (steel) and the blue line cross each other (a peculiarity of the provided selector valve) so instead of clamping the return line to the aft rudder bearing bolt (where it will rub the feed line) I will attach the return line to the feed line with a double adel clamp arrangement. This will keep the line secure while holding the two lines separate.
Feed line (blue) secure. Brake lines secure. Return (steel) line will be attached to blue line.
