Kupe's Zodiac 650B
Date:  8-25-2015
Number of Hours:  1.00
Brief Description:  Oil Filler Access Door Complete
Finished up the oil filler access door by updrilling all the pilot holes to A4 rivet size. I then removed the labeling from the parts, deburred the rivet holes, and filed/sanded all the surfaces to prep for final installation. Before riveting, I countersunk the holes in the fiberglass in anticipation of using the flat head attachment on the riveter. After that is was a simple matter of riveting everything to the upper cowl.
The oil filler door opening through the upper cowl.  The fill tube is just outboard of the hole.
Completed oil filler access door closed up.  Fits nicely.
Completed access door from the front.
