Kupe's Zodiac 650B
Date:  8-11-2015
Number of Hours:  1.50
Brief Description:  Complete Front Baffles/Start Baffle Seals
Finished up the front baffles by clecoing them back in place and riveting them onto the main engine baffles.
Began work on the baffle seals - heavy-duty rubber strips that run along the tops of the baffles and form a tight seal with the upper cowl. This job consisted of:
- Marking a drill line about 12 mm down from the top of each baffle.
- Marking drill points for the baffle fasteners.
- Drilling out the drill marks to a #20 (5/32") hole size.
- Cutting lengths of the baffle seal to fit the main baffles.
- Match-drilling through the baffle seal using the already-drilled holes in the main baffle.
- Securing the baffle seal to the baffle using clecoes.
That's as far as I got today on the left baffle. A test fit with the top cowl indicates it's going to work well.
Front baffles installed to the main baffles.
Left main baffle seal clecoed into place
Another view of the left main baffle seal.
