Began fitting the lower front baffles onto the cylinder baffles. These baffles channel the ram air into the baffle box surrounding the cylinders instead of escaping below it. I started by spending a few minutes smoothing/evening out the cooling port flange (after removing the lower cowl) to make the fit cleaner. Next, I drew and drilled out a rivet line in the bottom of the cylinder baffle box that the lower front baffle will attach to. Next, I trimmed the aluminum baffle material so that it fit better with the interior contours of the cowling. Then I drilled out the forward baffle to attach it to the cylinder baffle box. Tomorrow I add the outboard forward baffle.
Left side lower front baffle clecoed into place.
Left side lower front baffle.
Both cooling air ports, one with and one without the lower front baffle.
