Continued working on the spark plug leads this morning by adding the plugs to the ignition coil end of each lead. To do so I did the following:
1. Removed each lead from the engine baffles, one-at-a-time. 2. Stripped ~1/4" of insulation off of one end of the wire. 3. Attached a connector to the end of each wire with a crimp over the exposed copper wire and a crimp over the insulation. 4. Soldered the exposed wire crimp. 5. Inserted the connector into an ignition coil cover. 6. Attached the spark plug lead to its assigned post on the coil pack and rethreaded it into the engine baffle. 7. Repeated 7 more times for the other spark plug leads.
All 8 leads are now connected to their assigned ignition coils.
Connector crimped into place on a spark plug lead after soldering.
Right side ignition coil with spark plug leads attached.
